First thing to try after carefully inspecting the flange, dowels, & mounting surface of the flywheel, is to try installing it at 180 degrees from the first location and checking it again. If it's still out of spec, a person should check the crank flange and see what kind of flange end runout is there. It can be trued up if need be. The flywheel can also be chucked in a lathe and checked for warpage.
