Flywheel removal.
Terranova
I come to you fully hat in hand. Is the fly wheel pressure fit to the crank or should I be able to remove it with a couple swift taps of the hammer after I take the bolts out? I may have bitten off just a tad bit to much in this afternoons project. Thank you!
T
I think you are correct but will leave that to others. Be sure to mark the orientation of the flywheel and pressure plate for reassembly.
Charlie Stephens
I know you've now done it, but I found it easier if the dowel pins are orientated horizontally. It made a very slight difference.
Mart.
Mart,
Your videos have been the motivation that’s gotten me out to the garage to get this thing off the tire it’s set on for the last 5 years and mounted on the stand.
Thank you!
