i'm putting an 8ba eng in my 27T. i bought a 51 8ba rebuilt eng w/flywheel and clutch for the 51 trans. i'm using a 39 trans w/ 50 merc stamped bellhousing, so i took a flywheel and clutch off another 8ba truck eng , also the oil pan , i wanted the pan to bellhousing boltup bracket. PROBLEM..when i bolted the 8ba truck fly/w to the car 8ba eng. the flywheel hit the block and locked the eng???? why would there be a difference??? what solution/? machine back of fl/whl? spacer behind fl/whl? any ideas, thanks Boo
