After some trial and error, I got the flywheel housing within .002 all the way around. However, it took shims of .022 on one ear and .018 on the other, which is way more than the gasket on the block which was .011. Question is, how many shims are too many shims. Seems to me, and this is the question, that at some point the housing is going to be tilted relative the the crankshaft center line and hence the pilot bearing. The top of the housing at the shims is going to be farther away from the block than is the area around the gasket. Any experience, thoughts, suggestions? Thanks
