Jack Shaft
Henry was working with new parts !
I've wondered about checking in the car, and a light bulb justed turned on !! Thanks Herm
........................the engine is mounted by the housing .................. Duh
still can be done.easy with floatamotor's, a little harder with stock mounts..fact is if your going after clutch chatter and want to check the housing yard the engine..on heavy trucks it's way easier to pull the trans than engine...slide a jack and block under the pan,all modern stuff use a float a motor type mount.pretty common when doing a clutch..
