Dan McEachern
Another reason you can't shim between the 4 mounting holes is that the rear cam bearing seal relies on those two surfaces being in contact. Shims on the cam side for sure would compromise that seal. Then you will be screaming at your engine builder that the rear main is leaking when its the cam bearing.
