Dick Steinkamp
Is a Model A flywheel balanced "neutral'? In other words, can it be balanced by itself without the rest of the rotating assembly (except the pressure plate, of course)?
To answer your question, yes it can! Price is about $60 depending where you are. Indicate it well ( 0-0 ) in the lathe and you won't need much drilled out. My advice is to take the old starter ring gear off and replace it with a new un worn one after balancing. For my reasoning, Remember, an engine usually stops in the same place. That means that the starter engages, also in the same place, which translates to the wear all in the same place! Look at the teeth and probably half the teeth are ground off in that area. Imagine that much weight missing on the circumference of the flywheel it's self and what it would do to the balance. New ring gears are not that expensive.
Terry
Install new ring gear FIRST, balance flywheel, attach clutch cover and re-balance whole assembly making any correction by drilling spring towers.
