Thanks again Terry and Brent for your thoughts, I had thought about that possibility and was thinking if the machinist said it was close I might just leave it alone but if it happened to be out significantly in his opinion then I would have him correct it. This car was redone about 2005 but I don't have much info about what was done. Seems like some things were done well but I have corrected enough things that I have lost confidence in the work that the owner did himself. The engine has definitely been rebuilt and I hope that he didn't do it. I do have some vibration at higher rpms but with stock motor mounts it may just be the nature of the beast. I was wanting to just make sure he didn't just buy an engine and never checked the flywheel before putting it on. That is such a large mass of iron spinning I just thought it might be worth checking. I read so many different opinions about lightening on here that I couldn't tell if I should do that or not. I will study that some more.
