gdmn852
Yes, you are right starting out on flywheel balance,now on to valve train.Probably the next step would be to take off valve cover and drain tube,and see if valves are hung up on cylinder one and check valve lash on all. From reading past posts doesn’t seem to unusual for valves to stick on a engine that hasn’t run for awhile.
