Easy to do. Use a torch to heat it so it expands and push it off.
Heat the new one and drop it on. Work fast and have a hammer and drift handy to push it in place.
Be sure that you orientate the new one the same as the old one.
A wire brush is your new friend, and avoid overheating (no color). The cold flywheel and hot ring are the correct combination. A brass drift to seat the ring. Work around the flywheel to gradually seat the ring if tight fitting. I used dry ice and the barbecue.
The hard part now will be locating the dry ice.
This was on a Ford V8 flathead which has a directional ring gear. In other words you can put it on backwards...don't ask!... Chap
