Ed Northrop Senior Member Sep 7, 2013 #1 Could you use muratic acid to flush a radiator amazing results when flushing a hot water coil in a boiler
Tom Wesenberg Well-known member Sep 7, 2013 #2 That's pretty potent stuff and the fumes are very bad to breathe. I don't think I would want to try it.
marc hildebrant Well-known member Sep 7, 2013 #3 Muriatic Acid is an old name for a moderately strong solution of HCL or Hydrochloric Acid. Poor choice for this task. Marc
B Brentwood Bob Well-known member Sep 7, 2013 #4 not the best choice IMHO, Vinegar is fairly mild, and a better choice. You would want to remove any grease scum before you try the vinegar. That is why I chose simple green. Tom W. used cascade. Bob
