What I'm about to say will certainly create discussion but it's what I've done for years when rebuilding in excess of 2,000 carburetors including the early double venturi.
I have measured the smooth tip of a Torch Tip Cleaner and marked them in thousands so I end up with one at .021, .018, .019, .036, .037,.038, and .039.
I prefer to use original jets as some of the new ones available are junk.
I use a magnifiing glass to inspect the orfis of the jets to be sure they are not damaged. Jets don't wear out, just get dirty. It's amaizing the varitey of jet sizes that exist with original marked jets; example # 19 in most cases will measure .037 but you will also find some at .038 and .039. The compensator jet in the double venturi carburetor usually measures .036 and the later #19 usually measures .037. I always use a .021 Idle jet, some of the remakes will measure .022 to .024, way to big !!!.
I have arrived with a combination of jet sizes that seem to work well for me, run well, don't leak even when the gas shutoff is left on. I have never flow tested even one jet, sold numerous carburetors and garanteed the people their money back if not satified. The sold carburetors have helped to supported my "A" hobby over the years.
By the way, due to the hardness of the new jet gaskets, I use a tooth pick and put a small coating of Aviation Gasket Cement on them before installing the jets; I also use the same on the threads of the choke driver housing as the threads are below the bowl fuel level.
Again, this is only my opinion, so don't be upset with me.
Ron
