TDO
Just when I thought I had the Flo-Rate for the Model A and B carb. I got a surprise when I ordered a set of flow tested jets for my model B Zenith carb. from Dave Renner. I was using the flow chart from the book, Restoring the Model A and B carburetor the "Rex" Reheis way.
So when I got my jets from Dave Renners, I noticed that the flow rate on them was much higher than in Rex's book. So reading below the flow chart , I find that the flow rate was developed by Dave Renner of Renners Corner. So now I'm really confused. So I called Dave and asked him why there was such a large difference then what he had in Rex Reheis book.
He said he developed those flow-rates many a year ago, and since then he and two other guys had been experimenting with different flow-rates. And the ones he uses now work the best. Here are the two flow-rates.
Rex' Reheis chart
main -136-142
cap-372-462
compensator -110-118
idle-43-47
power-110-118
Dave renners new chart that came with my jets.
Flow thru the cap jet is not important as long as it flows more than the comp jet.
main- 153-157
comp -144-148
power -134-138
idle -49-52
These are for a model B carb. If any one has the ones they got with there Model A carb. I would like to no what Dave Renner is now using for there flow.
Rex' Reheis chart
main -136-142
cap-372-462
idle-43-47
power-110-118
main- 153-157
comp -144-148
power -134-138
idle -49-52
