Floorboards, wheel camber and body maker
saltman
* I have new plywood floors for my '28 Coupe and they fit great. I still have all the original boards and iron supports (although rotted and rusted). However, although I know I don't need the outer floor iron supports for the lower section, do I still need the inner irons to suppot the front/slanted piece?
* Any way to adjust camber of front wheel?
* Also, does anyone know who made the 1928 special coupe body?
SALTMAN
PS: To those of you that are going to suggest 'required reading' material... I have taken your advice and ordered the all the recommended 'how to' books.
Saltman - I don't use the iron support on my front slanted piece. Everything works fine.
As far as I know, camber can only be adjusted by "axle bending". Which can be done at a truck axle and frame shop.
I can't help you with the maker of your body, but I am sure there is someone on here that does. However, they may need more info.
Ron/IA
