floor pans
Woodie1
We have a 1939 that needs new rockers & floor pans. I'm aware of the bracing needed inside the body but I was wondering if anyone has tried to do the work with the car on the frame bolted down. If so, did it work out or was it more of a pain than it was worth.
I replaced both front pans in my '40 sedan with the body on the frame. Didn't have any more than the usual trouble. Used Bradley sheet metal and it fit very well. Did one side at a time and left the tunnel in place.
dw
I figured to use the original trans hump as well since the new one doesn't have the same size as the old one.
I did some small patches on my 36 on frame. 1"x1" on the rockers and the whole front passage side floor. No issues. You won't be able to grind the floor welds underside smooth, just have to treat it for rust.
Don W, When you replaced the rockers, did you do the whole part up under the cowl or just pieces in the door opening?
Didn't do rockers, just front floor pans.
I would think you might want to do each repair separately and remove only one piece at a time so as to maintain as much rigidity as possible. Just speculating, though. dw
Years ago I did a '35 roadster (entire)floors and rockers- on the frame and on the frame I used.Started at the cowl and worked our way back.Replaced the butchered firewall to begin with.To me that was the only way to do it.
deuce lover, These are the type of comments I'm looking for. It sounds like it can be doable versus having the body off the frame. Seems like I'd be better able to keep this aligned.
Replaced the rockers and pieces of the floor in a 46 Tudor on the frame. Since most of the pan was still attached, there didn't seem to be any alignment issues before or after. Hauling the car - and strapping it to the trailer - will put more stress on things than the metal work. Remember, there's a reason the rockers need to be replaced as they had long lost their battle with rust.
I would make sure I had the doors fitting nice before I started so I would have something to check as the project goes along.
