Bob, it’s really not that hard once you get the hang of it. Just make sure that center punch is sharp and that you punch the center of the rivet. After that carefully drill that punched area until your drill bit brings up a few slivers of rivet. Then, take a small ball peen hammer and use the center punch to tap the rivet through. You should be able to remove the rivets without enlarging the original hole.
Mike
