Floor boards
Jynx
A friend called tonight ,,he's building a 31 pick up..well a while back I gave him a print I found on the net for the floor boards..he wanted to make his own...well he moved and lost them and I cannot find them again..it was in PDF file,,,does anyone have a copy or know where i found them....if not I will take the ones out of my coupe for a tinplate
tks
I too am going to be building solid wood floorboards for a 1928. Neither Steve Waltrous' site, or the article in "How to Restore Your Model A" volume 6 shows all the dimensions for the early floorboard design. I could not find any by doing a search of Ford Barn either. Do Ford drawings exist for the early floorboards?
Elcastor,
What do you need concerning the early floorboards? They are very similar to the planked later 28 floorboards except for the emergency brake cutout. I believe I have an early set of 1928 floorboards without any cutouts for the emergency brake. They are not usable, but good for a pattern. If you need a dimension or two, let me know.
Rusty Nelson
Elcastor,
Rusty Nelson
Mine is an Oct 28 with emergency brake in front of the gear shift. It takes both the web site and the Ford later drawings to come up with plans for the 28 floorboards with still a little guess work. I was just looking for Ford's original drawings.
I believe A&L Parts Specialties sell a copy of the print for a dollar. They have different years available. I don't know much about them and if they are copies of the Ford prints. You might give Al a call at 860 693 0112. I made a set of planked floorboards for my Nov 28 special coupe. I know what you mean about a few dimensions missing. Luckily I had an original set of floorboards to take the missing measurements. If you are real picky, the long joints between the planks are a special style and hard to recreate, kind of a narrow, thin dovetail.
Rusty Nelson
Here is an EARLY set with the left hand brake & with out the cut out for getting to the throw out bearing..
Rusty Nelson
Thanks Rusty. I will give A&L a call tomorrow and ask what they have.
Ben
