I have a 58 Retractable with a new Holley 4160 carb that tends to flood when restarting the car when warm. It seems the pressure in the mechanical fuel pump is forcing fuel past the needle valve when the car is off. We've adjusted the floats to a below normal setting to compensate, but it doesn't help. The pump only puts out about 5 pounds. Is there any way to vent the pressure in the pump when the car is turned off? Or add a fuel return line to the tank? I'm trying to avoid going to an electric pump. Thanks for any help you can give.
