Clutch is jumpier tho...
When I installed my first set of FAMs, the rubber block that goes on the cross member looked too small - and it was. It soon fell out and from then on, till I made a new rubber block, the clutch shuddered something awful in reverse. As soon as I cast a new rubber, the problem went away.
Maybe you should look at that rubber block.
The new rear rubber block is certainly smaller than the old one, probably 3/8 inch on each side too short. I did get it a lot better by putting a couple turns on the bolts, it added a little vibration back, but it's still a nice trade off.
I doubt that's big enough, the one that came out is about 3/4 inch square and 4-5 inches in length.
Does FAM effect the alignment of the crank hole? Mine does not fit.
I am putting in a new motor later this year. Should the rubbers be replaced whenever the motor comes out?
