The first bunch of production A's had Ford's version of a float a motor and they quickly changed to the solid.
The original engine gets a pretty bad rap today because of vibrations. The problem is the original factory engine was tightly balanced. Most engines today are thrown together and the people do not own the scales or tooling to get the few gram balance of the moving parts and the close tolerence crank shaft grinding. The results are engines with vibrations and lower top end RPM.
So out of necessity some have to resort to FAM as they do not want or likely can not afford to have their engine rebuilt back to Ford specs. It is very hard to get close to Ford factory specs when you rebuild the engine.
The solid mounts are also structural with the frame giving it some rigidity. The A frame is VERY flexible, you might be surprised how easy it flexes if you have it mounted at a central point.
