Oh My!
What have I started, again! The rear end is still pushing against a similar "member" resulting in only a very slight rubber flexing of the rubber biscuit, not unlike the slight rubber flexing in the rubber pads between the stock mounts & the frame rails.
FAM's is NOT like mounting the motor with GIANT rubber bands! Bill W.
If its not unlike the slight flexing of the stock rubber pads then why change and give up the frame rigidity?
Think about it, with the stock mounts the frame rails can't twist at the rear mount area.
As the engine torques on the Floatamotors do to their design they try to twist the frame rails and their is less rigidity to stop it.
Model A frame rails are not real rigid and need all the help they can get.
Bill
