I had a cobbled together a 31 coupe that I have been repairing for the last few years. I have a float a motor engine mount with new rubbers and a stock mount for the front. The suspension is all correct now and the frame has been straightened. The engine front lines up, everything looks like it should- I think.
The problem is the clamshell is too close to the frame to install the rear float a motor transmission bracket. The question is, is the rear float a motor bracket necessary? I have been watching this forum for several years and don't post as I don't have any great desire to be insulted but for this problem it would be worth it if you also happen to have a knowledgeable answer. Thanks.
