While crawling around underneath my new-to-me 1931 Town Sedan I noticed that the nut on the main Float-a-Motor bolt was almost falling off. When that nut is not tight there is nothing really keeping the engine from rotating on the bolt during load.
The nut is an aircraft nut with small notches cut into the base of the flange (see photo). When the nut is snug against the washer and the rubber doughnuts are slightly compressed (per the installation instructions) the axial force from the rubber doughnuts keeps the notches dug into the washer beneath it and it won't rotate. What I surmise happened is that over the years the lower rubber doughnut has gotten compressed and the bolt lost that axial force. Normal driving introduced enough vibration to allow the nut to back itself off. I checked and the other side was just about to allow the same thing.
This doesn't seem to me to be the most robust of designs. To make sure that the nut stays tight to the bolt you could use nylon-insert nuts. Or, you could do the cheap solution that I did and install jam nuts.
Either way, the lesson learned here is that you should be sure you check these nuts periodically to make sure they aren't about to come loose.
(The photo/diagram of the Float-a-Motor is a screenshot of the directions that Bratton's allows you to download. Thanks, Bratton's!).
Best wishes.
JayJay
Best wishes.
JayJay
