Just found this on the HAMB by:Hyperborean
Gentlemen, Go to vaautoracing.org and click on L.O. Stanley who was a little known, but natural genius at high performance engines. He built many successful crossfire racing engines in the 1950's. First one I recall hearing of was driven by legendary Curtis Turner. He ground his cams, made his own distributors and modified the bottom end to stand the stress of firing two cylinders at once. His first attempt drove the crankshaft out the bottom of the engine! You dudes won't believe the intake manifold on this engine! On the outside, it appeared stock with a 1951 Mercury carburetor. He hid two more carbs UNDER the manifold that drew air through what appeared to be crankcase breathers! How he made the float bowls work, I'm still trying to figure. He also built 420 cu. in. flatheads, two of which are still running! NASCAR outlawed his engines from sanctioned races, Mickey Mouse then, Mickey Mouse now. He later worked for Holman-Moody and Ford engineering. Check the site. Anyone beginning to feel a little humble, now?
http://www.vaautoracing.org/oval6.htm
http://www.jalopyjournal.com/forum/showthread.php?t=242893
