From 38-48 Ford used three lengths of head studs, In 49-53 the 8BA used 20 bolts, 1.94" . In 49-53, 28 bolt engines used 2.62". Mercury, the same. Be aware the studs have different threads on each end, and should not bottom in the block. Removing studs for bolts is risky, as the threads in the block may be fragile.
Does anyone know when the Ford flathead V8 switched from head studs to head bolts ? Was it with the 8BA ?
Sal
I have a 48 - 51 Ford truck parts book and it only lists bolts.
I prefer using studs over using bolts......
First, that's what all the Flathead engines I own were originally built with at the factory...., second, I feel I can seal the threads on those studs that enter the water jacket a lot better than I could if using bolts....., and third, I feel I can control setting the torque a lot better when using studs, hardened flatwashers, and nuts, than I ever could using bolts. I believe the use of bolts to fasten the cylinder heads on our beloved Flatheads happened after Henry's death, and strictly as a cost saving measure. I have never been a fan of the 8ba versions of the Flathead engine, but if I ever build one to use in any of my old Ford's, it would definitely be built using studs, rather than head bolts, but then again, I wouldn't be building racing engines that may only last a few races, before their blown, and rebuilt maybe several times in a season, or maybe find it necessary to quickly pull a head to possibly make a repair between races.
So could you please tell me where I can find the correct studs (the correct three different lengths) for my C59A?
Michael @ Third Gen/Ford Bolts. Roy N. offered this kit and I'm assuming Michael is still offering it.
Or, you can order ARP studs individually from Allen's fasteners.
https://www.allensfasteners.com/
I ordered ARP studs for my build and it came to around $250 after their discount for ordering 50 or more. This was about 1/2 price of any pre-packaged kit from a vendor.
