bmwillia
Took a vacuum measurement. The gauge says its in the "Late Timing" range. How do I fix that?
Here is a video:
https://youtu.be/XcotyoNPuxI
Thanks!
Here is a video:
Thanks!
Is it better to check compression with the engine warm or does it matter?
Normally checked when warm, ie around running temp. Then if low a bit of oil down the bore and a rechecked to rule out rings perhaps.
Phil NZ
