When a stock Ford is modified with differant coils, switches, electric pumps etc it is hard to trouble shoot for problems. Having a differant coil was not mentioned in the inital post for help. With stock parts it is simple to find a problem as every engine is the same, problems are repetitive and can all be tested the same. These cars don't need round coils, 12 volts or electric fuel pumps they start and run great just like they are. There are problems with the stock coils due to materials used in that time period and age. Have your stock coil rebuilt and your starting problem is over for good at all outside temperatures. Skip has rebuilt over 13,000 old Ford coils and they all work and hold up good. NO ONE has ever been charged for a coil repair no matter how old it is. There have only been a few that had problems in all these years. A few have been damaged because the ignition switch was left on and in some cases with a battey charger hooked up, this really makes a melt down. In at lot of cases even the switch being left on don't damage the coil and the battery runs down first. If the points are closed the coil will get hot and may get damaged, if the points are open the coil is disconnected and there is no damage. All of this bandaid fixing is what leads to constant problems like the guy with the tow rope. If the wireing is bare and the insulation is breaking at least put in a new dash harness. The wires are all color coded and a simple diagram usually comes with a new one. Put in new 2/0 battery cables with good ends and clean all grounds where the cables contact the metal and put electical grease on the battery and ground connections. Do not use the green knob type battery shut off. I know I promoted these a number of years ago but have had problems with 3 of them, one recently where almost any load along with the coil causes a voltage drop. I run a GPS on 6 volts and it would shut down from low voltage every time I hit the brakes even with a 6 volt alternator that charges at idle. Late yesterday when I came back with the 39 I let it idle for a minute or so watching the digital volt meter below the dash and at a very slow idle it was showing 7.26 volts. After have having sluggish starter power and the GPS dropping out for several months one day after lunch there was nothing when I hit the starter. I got out and loosened the green shut off knob, retightened it and it started. I got a REAL battery disconnect, installed it and the starter spins like it has 12 volts applied and the GPS never drops out and will now continue to run even after the engine is shut of. It will however shut down when I hit the starter. Parts are not very expensive for these old Fords compared to newer cars. Fix it right the first time, it will be cheaper in the end and you will be able to drive and enjoy the car and not have the fear like the guy with the tow rope which gives advise to others?? G.M.
