I picked up my first flathead, a running 1940 221. It has new water pumps, a PowerGen alt., new carb, and a MSD electronic dist. I would like to just clean it up (gasket set, paint, etc.) and run it as is.
As for the stock heads, what is the best way to freshen them up? Should I get them bead blasted?
Also the intake is aluminum, can this also be bead blasted and left raw aluminum?
Thanks for any advice.
