Flathead Questions and concerns!!!!
Building a nice "X" or "K" member is pretty easy and really strengthens the "A" frame. and it ain't a 500 hp SBC
What is the best conversion f100 or 32
For a Model A, it depends on what you want to do, how you want it to look and what drive train.
I used an F-1 crossmember for my AV8 set-up. Looks factory and does add some strength.
It does make removing the trans. a little easier than with a '32 K member.
I don't think the 400jr will give you any chassis trouble anymore than any other cam.The issue here is fitting the engine and trans into the "A" so it's done safely and convenient to work on. The only problen you'll have with the JR is lifters.
