Last fall I purchased a 1936 Pickup. I do not know much about the history but the frame VIN checks out as a '36 and the transmission VIN matches the frame.
A few days ago my son and I started tearing down the engine and I am confused. I'm hoping someone can tell me what it is that I have.
The 21 stud heads are cast iron and are the early type with the water pumps on the front. The block is the mystery. It has the crab style distributor which from my research is for '42-'48 blocks but then those would have 24 stud heads. Also note in the pictures that the block has provision for water pumps in the block.
Is it possible that someone in the past has installed the later distributor? Are the distributors interchangeable through the years?
Sorry, lots of questions...any insight is appreciated.
Tim
Tim
