G GusnAlex Junior Member Mar 8, 2015 #1 Is it possible to mate a Ford V-8 flathead motor to a GM th350 transmission? Second part of my question: If it were possible how much work would it be frame and floor work to do this on a 1950 Ford car? Thank you.
paul2748 Well-known member Mar 8, 2015 #2 Do you have the trans? if not, Flat-O-Matic makes a conversion kit using a Ford C-4
Diavolo Member Mar 8, 2015 #3 http://www.wilcap.com/flathead.html#8BA350AT Also, Speedway sells something similar. I'm sure a jj alliance vendor will sell them as well, but I wouldn't be able to point you in that direction.
Ol' Ron Well-known member Mar 8, 2015 #5 Speedway sells an adapter that allows the use of an AOD, very easy to install and with an overdrive.
