Lsjuniper, I would be be checking for cracks before spending a lot of time on it. The bad ones are between the valves and the cylinders, the center cooling openings say big truck to me. If it passes the crack test, take the cam gear off to see if the bottom end will turn over, good luck Chuck S.
