I have a piston and ring question also, (I havnt quite figured out how to start a new post)I am fixin to rebuild a 41 3-1/16 bore v-8 The pistons in it are the 3 ring originals I want to go back with a set of aluminum pistons( NEW OLD STOCK ) will the aluminum pistons and factory cast iron rings be compatible with the thin cylinder liners?
or will I have to use cast iron replacement sleeves or will I have to bore the block and run the std. late 239 pistons?
Thanks !
Fordestes
Thanks !
Fordestes
