GOSFAST
I know that Ross will make custom piston sizes but can you get the metric rings to go with the custom pistons of various sizes as you described?
One of my current engines broke a piston pin retainer while I was flogging it on the dyno. The tiny little broken piece got jammed on the side of the piston and created a perfect groove in the cylinder bore. I was VERY happy I had only bored to +.060 during the original build so I could clean it up at +.125.
The power value difference between +.060 and other sizes will never be noticed on the street. In fact there is usually more potential in professional, time consuming, tuning than the favored overbore.
Question.... Can Scat cranks and rods be used with smaller than .125" pistons? For example can a scat crank and rods be used with Ross .060" pistons? or better yet can a Scat Crank and Rods be used with Egge or any other cast piston?
I brought this back up to let everyone here know what we decided to do about the piston sizes to put into inventory!
We chose to go with .070" and .080" overs, this will allow many blocks to be finished to an "in-between" size so to speak. Not to have to initially go to the popular .125" over.
We will also still stay with this combo however, the 3.312" (bore) x 4.250" (stroke), Eagle cranks, Scat h-beam rods, and Ross pistons!
Thanks, Gary in N.Y.
P.S. These will ALL be Ross (forged) pistons and have only the "metric" ring packs, 1.5, 1.5, 3.0. They will also be for various stroke combinations, mostly the OEM 4.000" and the also popular 4.250". There will be a "handful" for the not-as-popular 4.125".
Interesting. Is the 4.125" stroke down on a 4" Merc or is this a aftermarket crank?
