philipswanson
Does the exhaust type stand adapter and its bolts safely support the weight of a full dressed flathead? Anybody have problems with this set up?
Lack of stability. It's so easy for the engine stand to fall over if it hits a bump, nut, bolt,screw or anything else when trying to roll it along the floor or driveway. Especially so if the casters are small dia. Three legs just don't provide safe stability. Kind of like a 3 legged milking stool. Found out the hard way many years ago.
An 8BA can hold the full weight of complete engine using bellhousing.
Do not use a 3 legged engine stand. It must have have 4 casters. I removed
some parts to do some work on it Full engine was there at the start.
"Havlirs House of Fab" has them . They advertises on The HAMB all the time. They are in VirginiaSpeaking of Flatty engine stands; it seems to be getting very hard to find someone that makes these adapters or the "cradle like" brackets for flatheads, the one vendor "stumpy's fab works" seems to be non responsive and vern tardell seems to be out of them too, anyone know of vendors that make the side adapters or stands?
The three leg stand issue is not specific to flatheads, any engine is unstable when using them.
