derek costello
what is a flathead 1952 mercury oil pressure normally ???
So.... At 80psi on the starter with plugs out is excessive ????
Mine runs about 40 to 50 PSI on startup. I use Castrol 10w-50. After warm up and when it's really hot outside my pressure will drop down to about 10 PSI. With water temperature around 195. Flatheads depend on oil flow not so much on oil pressure. I am running a 286 C.I. flathead.
Hi oil pressure can have an erosive affect on the crank and bearings. 10 lbs at idle and 40 in cruise os all you need. Another thing you should know, when running a hi viscosity oil, the opening of the relief valve heats the oil to a very hi temperature, however, as the oil warms up and thins out he valve closes and everything is happy. BUT!!! if your still running 50 [lus pressure the oil will over heat and loose it's effectiveness. The factory when it designed this oiling system rex\comensed 10 at idle and 40 in cruise. At this pressure the all the oil coming from the pump is going through the bearings
