BUBBAS IGNITION
There has been lots of discussion on using a Vertex magneto on the street.
My job of the week is a vertex for a flathead to be driven every day and we have a few of these out there running very well.
First of all lets take a used Vertex ( hopefully in good condition which we will check) and test it on the machine. My concern here is for a good strong steady spark at low rpm ( concerning cranking speed etc). This one passes !! Point gap is verified and adjusted if needed.
Take mag lower end off ( Chevrolet lower end , mag is correct rotation for Flathead) . Special driver tool is needed ( may be made with old screwdriver).
This one has no brass advance weights in lower end meanng it has NO advance ( discussed in a minute)
I call the lower ends a "butt" and i have machined flathead lower mag butts in stock most of the time.
Install drive shaft ( also machined for flathead cover and drive gear ) and then install lower end to shaft and tighten hold down screws with locks etc.
And wall-ah you have a fairly cheap method of owning a flathead Vertex unit...
Absolutly the " hottest" spark you can have in a flatty!!!! Gap the plugs at .025 and let er rip !!!!!
