S slocobrar Junior Member Jul 3, 2010 #1 i pulled this eng. from a 41 truck, thought it was a 59 because of the 59ab heads but the block is cast A85 1 in the upper bellhsg. i,m sure you guys know what it is. thanks chuck
Ol' Ron Well-known member Jul 3, 2010 #5 Good point. Does it have the #99 on the top right corner of the intake manifold ?surface.
flatjack9 Well-known member Jul 3, 2010 #6 Also see if a pencil will rest on the ledge above the timing cover. If so it is pre 1945. Won't know what the bore is unless you remove a head.
