flathead heat sending units
Kentf1003
I have several flathead heat sending units and would like to identify them for the years they originated. Any Barners know of a list that shows the matching numbers? Thanks.
The single terminal type is the 8A-10884 and the double terminal is the 8A-10990. If you plan to sell them, I suggest testing them first to make sure they work. We had a handful of NOS senders that were no good. The brand new senders work ok, so if they don't test good, pitch 'em.
This may help. Info. is from 1949-51 Vol.2 of Mercury Overhaul Manual. I bet these interchange with FORD to some degree.
Here's how you test them. FORD is the same. Click on pic. to enlarge.
This is the END. Plus the Mercury Manual.
Not interested in selling them. Simply want to match up a pair for a 1946 59AB engine that is in going in my 40PU.
Prior to using, is their a preliminary resistance or continuity check that would spot a bad sender?
Thanks.
Kent the double terminal one would be same as an on off switch. 0 ohms when cold, and open cirrcuit when hot.
I can't tell you about the single termial one.
Did I read somewhere that there are two different single terminal ones?
BTW, 19Fordy's posted pictures cover the test procedure.
Thanks 19Fordy!
