Flathead Ford Rebuilt 59 AB engine
Salem
NJ
Price
2500.00
Very Nice rebuilt Ford flathead V8 59AB engine. Rebuilt by a friend of mine who has many flathead rebuilds under his belt; therefore, there is no paperwork on this. He saved me a lot of money as these are very expensive rebuilds. Original dome pistons with .030 over rings. He's been doing them for about 40 years and I've seen and heard his work after completion. This comes with a starter and a three mount "diver's helmet" distributor. I believe the plugs are new. This has been sitting in the garage for about two years waiting for my 5 window Model A build but, I have decided to use another flathead with a larger cam and different heads and intake. W-D 40 was sprayed in the cylinder heads and the engine was periodically turned for maintenance. Hook up the ignition system and you should be ready to start. You may want to turn down the flywheel as there is some surface rust. Also needs a pilot bearing. Water pumps were not checked so there is no guarantee on them. You provide the fuel system and generator. There is no shipping unless provided entirely by the buyer. Local pick-up is the listed shipping method.
