Flathead Ford/Mercury Motor 1949-1953
45yellowford
Idaho Falls
ID
Price
$1250
Running flathead engine. This is the Mercury engine with the 4 inch crank, the 8CM heads and the 4 bolt carb. We have run this engine up to operating temp and it has 25 pounds of oil pressure at a warm idle, and there is very little smoke. There is considerable more smoke at higher RPM. This is an ideal candidate for a flathead build.
You are welcome to come to my shop and check out the engine.For more information, call Tom at 208 524 3995
