E edwardbarras Member Nov 7, 2022 #1 1949 8ba 239 ci. ford v 8. The oil cannister has three holes in it. Input, output and is the third hole for a drain? thanks
Kube Super Moderator Staff member Nov 7, 2022 #2 edwardbarras said: 1949 8ba 239 ci. ford v 8. The oil cannister has three holes in it. Input, output and is the third hole for a drain? thanks Click to expand... yes.
P pistonbroke Well-known member Nov 8, 2022 #3 Oil goes in through the upper side , out through the bottom center and the angle bottom port is a drain to empty the canister when doing a oil change. Tim
