flathead fan pulley/hub ID?
Montana32
New member
I need help identifying this flathead fan pulley/ hub. Anyone know what it came on? Do any of you have one?
Here is some additional information about the pulley/hub:
pulley/hub depth is 2"
the pulley is a 4 1/2" D narrow belt pulley
the one pictured has had a new shaft/bearing installed and the shaft sticks out of the pulley/hub (not cut to original length). Originally there was a sheet metal cap in the hole covering the shaft.
Thanks for any information you might have.
Steve
http://s1331.photobucket.com/user/s... fan pulley hub/IMG_1916_zps205977d7.jpg.html
http://s1331.photobucket.com/user/s... fan pulley hub/IMG_1915_zps7cdcf3aa.jpg.html
http://i1331.photobucket.com/albums/w590/sorg1932/flathead fan pulley hub/IMG_1914_zps96b9b33e.jpg
http://i1331.photobucket.com/albums/w590/sorg1932/flathead fan pulley hub/IMG_1918_zps6860a943.jpg
Looks like an industrial application of some type. Perhaps marine?
Did marine applications have a fan? I thought they pulled water from outside the boat and cooled it that way.....
What industrial applications used flathead Fords or Mercs?
