41LjH
- City
- Winston Salem
- State
- NC
- Price
- $8500.
Flathead build
Completely rebuilt with new parts.
Engine block cleaned in electrolysis tank, re cleaned by the machine shop and crack checked.
Bored 0.060 Rebuilder’s Choice 4 ring pistons (Egge pistons)
Hastings rings.
new cam bearings (Durabond)
original cam regrown by Holman Moody (Isky 400 jr grind).
stainless valves, reground seats, Johnson lifters, Isky valve springs.
connecting rods re-conned, new bearings (Clevite P.)
Original 4” crank checked and turned. New crank bearings (Celvite P.) Center main blower strapped.
Melling 19 oil pump
Best gasket set (copper head gaskets)
EAC heads clearance d for valve lift.
Truck water pumps
Flywheel resurfaced
Starter rebuilt for higher torque,
Currently this engine is set up for a 12 volt negative ground electrical system. Below are the 12 volt modifications.
Mallory Unilite electronic distributor. Jim Lender AKA Bubba coil. New 8MM wires
Fuel pump rod plugged. Set up for an electric fuel pump. Removing these items will allow the installation of 6 volt positive ground components and a 6 volt positive ground electric fuel pump for 6 volt operation.
This engine is offered with a Edelbrock 1802 500 CFM carburetor on a Offenhauser aluminum Intake.
Thanks for looking !
PM or call 336-422-1956 and leave your name and number. I will call you. I do not text
Hastings rings.
Melling 19 oil pump
Truck water pumps
Flywheel resurfaced
