Hello, could you please advise on the best way to prevent rust in the original 1939 flathead engine during long-term storage?
Should I drain the cooling system completely, or is it better to leave coolant in the engine? If coolant should be used, what type do you recommend?
The local climate is mild, with spring-like temperatures most of the year and only a few months of low humidity.
