flathead engine cradle
big deuce
Looking for pics of a flathead engine cradle/stand that mounts on both the front and rear of the block, from what I remember. Any pics?
Are you talking about the one that allows you to rotate it while it's in the cradle or just wheel it around?
Yes, rotating while it's in the cradle. Seems I remember a pic where there was a circle, or semi circle on each end that it rotated on.
i make em to mount on the exhaust flange's, like the motor rebuild stand, but two with wheels. pics tomorrow, its dark and i get scared out in the barn
I believe this is the style I was searching for
I think you are looking for the Clayborn type stand. Have a couple BUT not the adapters for each end. Just have one set of the adapters which I had copied from originals. sorry I can not give more info or pictures . kerk
I have 3 of them Claybourne stands...love them.
You can install the camshaft with it attached thats why it has a large hole in one end.
You can easily throw the boringbar on it won´t break a sweat..
Beats a sidemount any day !
Here's a couple of photos of the end pieces.
Great stand , I have the stand but need the 2 end pieces that Don has pictured above. I believe my Clayborne stand my have come from Don.
If anyone has the two ends pictured above & would part with them I would be very interested.
Thanks
Cheers
Tony
Thanks, I learned something today and if I ever see a Clayborne engine stand at a swap meet I will know what I am looking at and will treat it with respect. Time to go get the pizza.
If these are not being currently made, I bet Stumpy's Fab works would make these up if some one gave him the specs or a sample
They are not that easy to copy if you want an accurate copy since some pieces are cast.
A modern version with CNC machined part will not be very cheap either sadly.
I wouldn't think they would be too hard to fabricate, would they? A 2" slice off a 6" (or so) steel pipe and some 1/4" X 2" steel strap and you're well on your way to making the first (circular) part. A piece of the proper sized tubing, a steel plate, and some proper sized bolts and you have the second. Granted, it would take some cutting and welding, but if I had the stand without those parts, I would be at the steel supply shop this afternoon, digging through the "Drops" bin.
I nhave the stands so if anyone has the end pieces I would be interested. I would swap the stand for the end pieces !! kerk
I ran across this stand, had the Clayborne tag on it, but not sure of application. For sure not flathead.
