I am finally in the assembly mode of the 8ba. It ended going .060 over on bore, and .010/010 on crank. I have a few questions. I have washed the block with soapy water, used brake cleaner, and compressed air to clean the block and crank including the throws of the crank.
Questions:
1. Is ISKY rev lube good to put on the crank mains, connecting rod bearings, cam, lifters, rods, etc.? Should I use something else? I already bought a container of it in addition to the little container that came with the cam.
2. Should I use new bolts for the main caps? Get a set of ARP or?
3. connecting rods, old nuts good, or do I need new ones?
4. Main cap bolts, do they go in dry or should I use anti-seize or lock tight?
5. Nuts on conn rods, dry, anti-seize, or lock tight? I have the thin locking nuts that go on top of the nuts too.
6. There is a bushing for the fuel pump rod, does this need to be replaced or checked before I put this engine back together?
Sequence:
1. put main bearings in dry
2. put crank in dry
3. bolt main caps w/bearings on dry
4. individually plastigage and make sure each bearing is at .001 to .003
5. remove crank
6. install main bearing seal
7. install one piece front oil seal
8. lube the mains with Isky Rev Lube (IS THIS OK or do I use something else?)
9. bolt main caps on
10. make sure it still spins fairly smooth
11. Move on to pistons and connecting rods - I'm sure more questions will come.
12. Put cam and spring assemblies back in.
Questions:
Sequence:
2. put crank in dry
5. remove crank
