1928Fordman
Hey guys I have a couple of questions for you.
1. Will this Camshaft work in my engine?
2. What do I need to use this Distributor on my engine?
The block that I have is a 59AB that has the reliefs in the block around the valves. The cam is a regrind with .385 lift. I believe it was a later 8BA 49-53 cam that was converted to the earlier style. The heads that I have are the new block letter heads from Edelbrock. I have both a 2 bolt and 3 bolt front timing cover. The distributor is a 3 bolt 37-41 Mallory. Thanks
