Flathead Block and 4" Crank Shaft
45yellowford
Idaho Falls
ID
Price
in ad
SOLD SOLD SOLDAre you tired of finding flathead motors only to discover later that they are cracked!!!! This is the nicest block I have seen in years. I had it hot tanked and maged, the common crack from a head bolt hole to a water passage hole was the only crack. The block has not been rebored and it has only a real small ridge at the top of the cylinder. I am asking $950 or best offer.
This is the crank from the above block. I had it cleaned maged and reground. everything checked out excellent. It is ground M 10, R 20. I am asking $550 or best offer. If you are building a high dollar flathead, this is the place to start.
The pan, timing gear cover,rods,oil pickup tube, etc are available.
