Flathead 8 and power brakes.
Howdy all.
I have a 30 Model A I bought off an estate a while back. The owner was going for a 50's 'ish' build.
Why am I here rather than the Model A forum? The car came with a 48 truck flathead V8 (that's why i bought it) and a Speedway brake/clutch master cylinder kit. Which has a power master cylinder.
Question - Can the flathead provide enough vacuum for the master cylinder? If so, are there any tricks/mods needed to do so, or can I just run the vacuum from the intake manifold?
Hella Street Vacuum Pumps 009428087
In the "notes" section for the above pump it states:
"This is not designed for use with power brakes; it is designed to control vacuum operated accessories. If used in conjunction with power brakes, it may not be sufficient as the main vacuum source".
Summit has other pumps recommended for use with power brakes:
https://www.summitracing.com/parts/ado-20939308?rrec=true
I kind of agree with tubman above - what vacuum is your engine producing?
No matter which way you go, the use of a vacuum reservoir (lots of different ones available) is a good idea in my opinion.
Yours is a 48' engine and mine is s 53', but yes the flathead provides enough vacuum for a power brake system. Mine is a factory Treadle-Vac, power brake booster, with a factory vacuum tank, under the driver side floor, bolted to the frame.
If you are still 6 volt pos ground you can always find and install an Electro-Vac unit.
540829
540830
540831
I only saw one that comes to mind. It was on a 52/3 ford and had an adapter under the carb with a larh (1/2") line to the master cylinder vacuum unit. Not sure how it worked, it waz along time ago!!
Gramps
Thanks everyone.
The car was converted to 12v Neg ground, so it looks like, if needed, one of the aftermarket units should work. I'll check the engine vacuum first.
Gramps
This is how mine is routed, from the back the manifold, to the booster, on my 53' Merc, with a check valve at the booster. The last picture shows the hose coming from the vacuum tank mounted under the car.
Check the amps required to run an electrical vacuum pump . I would just run the engine vacuum with a extra holding tank. Easier and probably cheaper . Just my opinion.
